When is it better for prefetch buffer to be enable and when is it better for it to be disable?
Rahma.1
waclawek.jan
There is no reason to switch it on when system frequency is set low enough so that there are 0 waitstates when executing program from FLASH, or when executing program from RAM.
When FLASH waitstates are nonzero, setting prefetch ON increases performance but also slightly increases power consumption.
Rahma.1
