When I give a PWM signal to PB1, cannot set PB2 pin to HIGH status
  • March 12, 2024
  • 1132 views
I am using my custom board PCB with STM32F103C8T6 MCU. I want to give a PWM signal to PB1 pin & want to set PB2 pin to HIGH. While giving the PWM to PB1, although I set PB2 pin status as HIGH, when I measure the voltage of PB2 pin it shows '0V' value. I am using keil uvision to developed the firmware. How do I solve this problem? Can I set PB2 to HIGH while giving a PWM to PB1?
Best answer by Tesla DeLorean
Should be workable. PB2 could be driven as a GPIO independently of what any other pin is doing.
Imagine that we can't see your design, wiring or code...
Tesla DeLorean
Tesla DeLoreanBest answer
Guru
March 12, 2024
poojaniAuthor
I cannot see your text fully. Can you repost it
