WFI problem
adrian4
Posted on June 25, 2009 at 20:54
WFI problem
11 REPLIES 11
adrian4
Posted on May 17, 2011 at 13:13
Spot on Andreas.
NVIC_GenerateSystemReset() did the trick.
It is now functioning as I intended.
Thanks very much.
Can you tell me where this function is documented with this level of detail?
The ST FWLib document just tells you that the function exists and a one line example of its use.
Cheers
Adrian
andreas2
Glad it helped.
The Cortex behavior is from ARM documentation. The firmware library calls are ''documented'' in the form of the C source code they're shipped as... :p
I find the FWLib docs largely useless, it looks more like an auto-generated list of functions (and I get more or less the same info from ctrl-space in Eclipse). I usually have to match the source code to the register descriptions in the ref manual to see what a function actually does.
