Wanted To confirm The IDE for the development
Adithya_Jayaram
Hi we're using STM32L412RB controller for our development wanted to know what are preferable IDE that can be used for the software development for the purchased controller.
STTwo-32
Hi again @Adithya_Jayaram
I personally recommend the STM32CubeIDE wish is open-source and will meet perfectly your needs. If you are looking for other IDE, I suggest you use Keil and IAR for your project (both are under license).
Best Regards.
STTwo-32
5 REPLIES 5
STTwo-32
Hello @Adithya_Jayaram and welcome to the ST Community.
I advise you to use the last versions of STM32CubeIDE (all-in-one multi-OS development free tool) and CubeMX
(a graphical tool that allows a very easy configuration of STM32 microcontrollers).
Best Regards.
STTwo-32
Any other IDE's? other than STM, please give me couple of options so I could check if i can get the license for the same(as it's a corporate project have to get the license for the same so need options ).
STTwo-32
Best Regards.
STTwo-32
Adithya_Jayaram
Hi , we're suggested to use eclipse, just wanted to know is it compatible with STM32L412RBT6P.
Southbranch
Senior II
Good questiion,
I am using CubeIDE but I plan to test out Viusal Studio Code with the add-in for STM32. Has anyone tested this, pros and cons? What about pin-configuration possibilites?
