Vref- minimum on stm32f103
j-fischer-gundlach
Posted on February 06, 2014 at 09:26
Hello together,
i´ve been searching for information about the minimal voltage wich has to applied to Vref-.
In particularly it is around the stm32f103CBT6. I´ve used the search function in the RefManual, but could only found out that Vref+ must be >= Vdd.
How´s about Vref-?
Has someone a hint to respective document?
best regards,
JFG
chen
Posted on February 06, 2014 at 10:30
Hi
''i´ve been searching for information about the minimal voltage wich has to applied to Vref-.
In particularly it is around the stm32f103CBT6. I´ve used the search function in the RefManual,''
The information you are looking for should be in the data sheet for the specific part you have.
There should be a section on absolute voltages - that is what you are looking for.
Data Sheet
NOT reference manual.
j-fischer-gundlach
Posted on February 06, 2014 at 11:47
The datasheet makes only an standment at the list entry for conversion voltage range. This range´s minimum is defined as ''Vssa or Vref- tied to Ground''. So i guess this is the information i´m looking for. Lowest potential is Ground.
chen
Posted on February 06, 2014 at 12:06
Hi
I have not looked at the data sheet.
I do remember in another thread/post, clive1 saying that the ADC CANNNOT read negative voltages. By implecations - the ADC reference cannot be negative.
This ties up with what you have found in the data sheet.
