virtual comport drivers
Options
‎2010-10-27 1:26 AM
Posted on October 27, 2010 at 10:26
3 REPLIES 3
Options
‎2011-05-17 5:13 AM
Posted on May 17, 2011 at 14:13
i downloaded the virtual comport pc drivers and installed in my pc but in device manager it was not showing any virtual comport .
...................................ple replyOptions
‎2011-05-17 5:13 AM
Options
‎2011-05-17 5:13 AM
Does anything happen at all when you plug your target into the PC?
What target hardware are you using - your own custom design, or an eval board or dev kit, etc? Are you sure that the application is correctly loaded and running in the target? Did the application build ''cleanly''; ie, with no errors and no warnings? What debugging have you done?
