Using the encoder mode with TIM4
martinmartin9130
Posted on March 04, 2013 at 21:06
Hi all, I'm using an STM32F4Discovery (it's and STM32F407VGT6 on it).
I'm trying to use the TIM4 timer to read a quadratic encoder (plugged on PB6-PB7), but somehow, it doesn't work.
I'm using exactly the same code with TIM8 and it does work (plugged on PC6-PC7). I validate the working code by reading the counter in GDB after turning the encoder by hand.
void
configureEncoder
RCC_AHB1PeriphClockCmd
RCC_AHB1Periph_GPIOB
ENABLE
RCC_APB1PeriphClockCmd
RCC_APB1Periph_TIM4
ENABLE
GPIO_InitTypeDef
GPIO_InitStructure
GPIO_InitStructure
GPIO_Mode
GPIO_Mode_AF
GPIO_InitStructure
GPIO_Speed
GPIO_Speed_100MHz
GPIO_InitStructure
GPIO_OType
GPIO_OType_PP
GPIO_InitStructure
GPIO_PuPd
GPIO_PuPd_NOPULL
GPIO_InitStructure
GPIO_Pin
GPIO_Pin_6
GPIO_Pin_7
GPIO_Init
GPIOB
GPIO_InitStructure
GPIO_PinAFConfig
GPIOB
GPIO_PinSource6
GPIO_AF_TIM4
GPIO_PinAFConfig
GPIOB
GPIO_PinSource7
GPIO_AF_TIM4
/* Configure the timer */
TIM_EncoderInterfaceConfig
TIM4
TIM_EncoderMode_TI12
TIM_ICPolarity_Rising
/* TIM4 counter enable */
TIM_Cmd
TIM4
ENABLE
I expect my error to be simple, but I'm blind. I did not forget to move the physical wires between TIM8 and TIM4.
Both full codes are here:
https://gist.github.com/nraynaud/5082298
If you want some Stackoverflow love, here is the question:
http://stackoverflow.com/questions/15203069/stm32-rotary-encoder-config-on-tim4
Thanks for your help,
Nico
#stm32-timer-counter
4 REPLIES 4
Posted on March 04, 2013 at 22:07
Maybe initialize the time base?
  TIM_TimeBaseStructure.TIM_Period = 0xffff;
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
martinmartin9130
Posted on March 04, 2013 at 22:25
It works, thanks!
Can you explain me the diference between TIM8 and TIM4 w/r time base initialization please ?
here is my working code for googlers :
void
configureEncoder
ENABLE
RCC_APB1Periph_TIM4
ENABLE
GPIO_InitTypeDef
GPIO_InitStructure
GPIO_InitStructure
GPIO_Mode
GPIO_Mode_AF
GPIO_InitStructure
GPIO_Speed
GPIO_Speed_100MHz
GPIO_InitStructure
GPIO_OType
GPIO_OType_PP
GPIO_InitStructure
GPIO_PuPd
GPIO_PuPd_NOPULL
GPIO_InitStructure
GPIO_Pin
GPIO_Pin_6
GPIO_Pin_7
GPIO_Init
GPIOB
GPIO_InitStructure
GPIO_PinAFConfig
GPIOB
GPIO_PinSource6
GPIO_AF_TIM4
GPIO_PinAFConfig
GPIOB
GPIO_PinSource7
GPIO_AF_TIM4
TIM_TimeBaseInitTypeDef
TIM_Period
0xffff
TIM_Prescaler
0
TIM_ClockDivision
0
TIM_CounterMode
TIM_CounterMode_Up
TIM_TimeBaseInit
TIM4
TIM4
TIM_Cmd
TIM4
ENABLE
Posted on March 04, 2013 at 22:55
TIM1 and TIM8 are ''special'', advanced I guess is the documented term, but there might just be something about how they are initialized, an ARR of zero basically disables the counter. My general rule is to not assume anything is in a reset/default state, and initialize it explicitly the way I want it to work.
martinmartin9130
Posted on March 04, 2013 at 22:59
Thanks, I'm at such a basic level of understanding of those beasts that I don't even know yet what is the minimum initialization required.
