using LFN feature in sd card with stm32f4
alianvari
Hi,I want to use lfn feature in sd card and i use stm32f4 for this purpose i set _USE_LFN to 1 and _MAX_LFN to 255 . when i create the file , file is created but when i want to return file name , returns wrong.
please guide me, how to return file name when i use lfn feature?
i attache the code.
unsigned char save_file_sd_log(void)
rtc_get(NO_CHANGE);
delay_ms(5);
if (INSERT_SD ==0)
res=disk_initialize (0);
if (res==FR_OK)
rtc_get(NO_CHANGE);
res=f_mount(&SDFatFs,"1:/", 1);
if (res!=FR_OK && res!=FR_EXIST)
sprintf(str,"save log to sd ERROR f_mount:%d",res);
debug(str);
return 0;
res=f_mkdir ("1:/LOG");
sprintf(str,"save log to sd ERROR f_mkdir:%d",res);
debug(str);
return 0;
if(AA_SaveOnCycleFile==1)
sprintf(name_file_str,"1:/LOG/CYCLE%02d%02d%02d.log",year_shamsi,month_shamsi,day_shamsi);
res = f_open( &SD_File , name_file_str ,FA_OPEN_ALWAYS | FA_READ | FA_WRITE);
else
sprintf(name_file_str,"1:/LOG/EVENT%02d%02d%02d.log",year_shamsi,month_shamsi,day_shamsi);
sprintf(str,"save log to sd ERROR f_open:%d",res);
debug(str);
return 0;
res = f_lseek(&SD_File, SD_File.fsize);
f_close(&SD_File);
f_closedir(&SD_dir);
sprintf(str,"save log to sd ERROR f_lseek:%d",res);
debug(str);
return 0;
f_printf (&SD_File,"%s",log_trigger_sd);
res=f_close(&SD_File);
return 1;
else
debug("disk Not Initialize!");
return 0;
else
debug("NO Insert Card!");
return 0;
unsigned char find_files_sd(void)
if (INSERT_SD ==0)
if (res==0)
sprintf(str,"<ERR*SD NOT Ready:%d*>\r\n",res);
if (start_debug==1) print(DEBUG_PORT,str);
else if (start_debug==2) print(LAN_PORT,str);
return 0;
res = f_findfirst(&SD_dir,&fno,"1:/LOG","*.LOG"); /* Start to search for log files */
sprintf(str,"<FFILE*");
  while (res == FR_OK && fno.fname[0]) /* Repeat while an item is found */
sprintf(str,"%s*%ld*", fno.lfname,fno.fsize);
 res = f_findnext(&SD_dir, &fno);        /* Search for next item */
sprintf(str,">\r\n");
else
sprintf(str,"<ERR*disk Not Initialize!*>\r\n");
else if (start_debug==2) print(LAN_PORT,str);}
else
sprintf(str,"<ERR*NO Insert Card!*>\r\n");
return 0;
return 1;
dbgarasiya
Senior II
I am attaching you one screenshot for that
5 REPLIES 5
dbgarasiya
Senior II
you have to update in your .ioc file in Fatfs part
USE_LFN should be enable
I din't notice . Can you explain more?
what is .ioc file?
dbgarasiya
Senior II
means in hardware configuration file, where you configure hardware pin for sd card
dbgarasiya
Senior II
thanks
