2011-08-23 4:41 AM
I want to access USB stick using STM32F205ZC. Whether keilV4.20 and st-link debugger will support debugging for OTG or not any suggestions please.
2011-08-23 6:58 AM
Depends on what debugging you expect it to be able to do.
If it is timing sensitive, then a debugger pod stepping or breakpointing is too invasive. Suggest you attach a serial terminal, and output controllable levels of debug/telemetry data. Have a U-Link or J-Link to hand in case the ST-LINK doesn't cut it. Frankly I've found the ST-LINK's to be more than adequate, but then I'm not constantly single-stepping my own code to figure out how it works. YMMV2011-08-23 9:00 PM
Thanks for your valuable information and suggestions!
2011-08-25 1:37 AM
Is it preferable to consider
STM32F105VC or
STM32F107VC (OTG) for
USB stick access?(are there are any limitations or problems we may get if I use these ICs)
