usb on nucleo-f412zq
farshid najafloo
Posted on June 11, 2018 at 07:38
I am going to use usb on nucleo-f412zq but there is no HSE on the board how can i setup clock configuration to use usb? Thanks.
Khouloud GARSI
Lead II
Posted on June 11, 2018 at 11:45
Hi
farshid
You may use the HSE in bypass mode (but HSI cannot be used).
I advise you to have a look on this discussion:
https://community.st.com/0D50X00009XkVtDSAV
Khouloud.
Khouloud GARSI
Lead II
Hi
farshid
Khouloud.
Posted on June 11, 2018 at 12:27
Should be an 8 MHz signal for HSE provided by the ST-LINK.
