USB is not getting detected
muralij21
Posted on October 06, 2010 at 09:22
7 REPLIES 7
xacc
Posted on May 17, 2011 at 14:10
Make sure you have the pullup on the data pins turned on (depending on USB speed, this will be on different lines).
hli
If you mean no detection at all, try the resistor but once it is detected but not recognized, please have a look on the USB PLL clock.
muralij21
greg_t
you need pull up on your D+ line
muralij21
I connected the pull up resistor of 1.5k from D+ to VSSA. I got a warning msg ''One of the USB devices attached to this computer has malfunctioned and windows does not recognise it''
muralij21
I tried it but still i am getting the same error. Any other suggestions..? please
xacc
VSSA is Analog Ground. It need 3.3V for a pullup.
You should connect it to a GPIO pin that you can toggle.
