Probelm with FSMC Keil ULINK2 uVision and Debugging
kzawada
Posted on October 05, 2010 at 16:52
xacc
Posted on May 17, 2011 at 14:10
Strangely enough, I get similar instabilities using a FDTI based JTAG debugger with OpenOCD connected to GDB when using external SRAM.
xacc
Did you ever solve or find a workaround for your problem?
Have you tried other JTAG debugger?
I just ordered a JLink one, and will let you know if I suffer the same results as previously.
