Unable to get ADC INTERRUPT
pavan2
Posted on January 29, 2009 at 03:20
16 REPLIES 16
pavan2
Posted on May 17, 2011 at 13:00
i am trying to get ADC reading in interrupt.i have kept adc in continuous conversion mode, with EOC interrupt enabled.
i assumed that i should get interrupt after each EOC from where i can then collect the ADC reading.
but i have been unable to get any interrupt from ADC.
i checked the ADC by polling, where i get correct the reading.
i am using RIDE 7 with GCC. and ST library functions.
NVIC CONFIGURATION
NVIC_InitStructure.NVIC_IRQChannel = ADC1_2_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;//0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE);
ADC CONFIGURATION
ADC_InitTypeDef ADC_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
GPIO_Init(GPIOC, &GPIO_InitStructure);
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_InitStructure.ADC_ScanConvMode = DISABLE;
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfChannel = 1;
ADC_Init(ADC1, &ADC_InitStructure);
ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 1,ADC_SampleTime_239Cycles5);
ADC_Cmd(ADC1, ENABLE);
ADC_ResetCalibration(ADC1);
while(ADC_GetResetCalibrationStatus(ADC1)!= RESET);
ADC_StartCalibration(ADC1);
while(ADC_GetCalibrationStatus(ADC1) != RESET);
interrupt handler
void ADC1_2_IRQHandler(void)
if(ADC_GetITStatus(ADC1, ADC_IT_EOC) != RESET)
ADC_TEMP1 = ADC_GetConversionValue(ADC1)&0x0FFF;
i trigger ADC using
ADC_SoftwareStartConvCmd(ADC1, ENABLE);
after this i assume i should get interrupt on each conversion.
i guess i am missing something.
but dont know what.
thanks in advance.
pavan k
[ This message was edited by: pavan.karmakar on 28-01-2009 06:38 ]
jgalea
Hello, I have a similar problem. Im trying to convert the ADCs with DMA but Im having no DMA interrupt. Not sure if the ADC is working. I also posted in the forum:
http://www.st.com/mcu/forums-cat-7896-23.html
. I also sent a technical question to ST as I still did not have a reply from the forum. If a get a technical answer from ST, I will send it to you. Thanks Johann
jgalea
Hello. I still have no answer from St technical support. In the meantime Im working to fix the line. I will notify you. thanks. To tell you the truth, I ran out of ideas, as followed examples. Im feeling in the corner :)
pavan2
i am right now trying to get the ADC working using DMA, i will update on successful implementation.
thank you
pavan k
jgalea
sofiene
Posted on May 17, 2011 at 13:01
Hi jgalea;
I have the following code that works correctly (ADC-DMA):
int main(void)
#ifdef DEBUG
debug();
#endif
/* System clocks configuration ---------------------------------------------*/
RCC_Configuration();
/* NVIC configuration ------------------------------------------------------*/
NVIC_Configuration();
/* GPIO configuration ------------------------------------------------------*/
GPIO_Configuration();
/* DMA1 channel1 configuration ----------------------------------------------*/
DMA_DeInit(DMA1_Channel1);
DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)ADC1_DR_Address;
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ADCConvertedValue;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
DMA_InitStructure.DMA_BufferSize = NumberOfSample;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
/* Enable DMA1 channel1 */
DMA_Cmd(DMA1_Channel1, ENABLE);
/* Enable DMA Transfer complete interrupt */
DMA_ITConfig(DMA1_Channel1, DMA_IT_TC, ENABLE);
/* ADC1 configuration ------------------------------------------------------*/
ADC_InitStructure.ADC_ScanConvMode = ENABLE;
/* ADC1 regular channel14 configuration */
ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 1, ADC_SampleTime_1Cycles5);
/* Enable ADC1 DMA */
ADC_DMACmd(ADC1, ENABLE);
/* Enable ADC1 */
/* Enable ADC1 reset calibaration register */
/* Check the end of ADC1 reset calibration register */
while(ADC_GetResetCalibrationStatus(ADC1));
/* Start ADC1 calibaration */
/* Check the end of ADC1 calibration */
while(ADC_GetCalibrationStatus(ADC1));
/* Start ADC1 Software Conversion */
while (1)
if (PrintFlag == 1)
printf(''%d\n'',ADC_Average);
PrintFlag = 0;
//////////////// DMA IRQ routine //////////////////////
void DMA1_Channel1_IRQHandler(void)
for (n=0; n
ADC_Sum = ADC_Sum + ADCConvertedValue[n];
ADC_Average = ADC_Sum/NumberOfSample;
ADC_Sum=0;
PrintFlag = 1;
DMA_ClearFlag(DMA1_FLAG_TC1);
//////////////// NVIC config //////////////////////
void NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
#ifdef VECT_TAB_RAM
/* Set the Vector Table base location at 0x20000000 */
NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else /* VECT_TAB_FLASH */
/* Set the Vector Table base location at 0x08000000 */
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
/* Setting the priority grouping bits length */
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
/* Enable the DMA global Interrupt */
NVIC_InitStructure.NVIC_IRQChannel = DMA1_Channel1_IRQChannel;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
jgalea
Hello. Im going to try it now and notify you many thanks Johann
jgalea
Hello. Thanks for the code. Unluckily the DMA did not occur in mine. Please, was the ADC1_DR_Address set as ((u32)0x40012444C)?. Please how was ADCConvertedValue decalred? Thanks Johann
sofiene
First I'm M3allem and not Johann :);
Sorry I missed some declaration in my code:
#define ADC1_DR_Address ((u32)0x4001244C)
#define NumberOfSample 50
u16 ADCConvertedValue[NumberOfSample];
B.R.
M3allem
