Touchgfx : wil the keyboard example be supported with 4bpp and lower resolution?
Options
2021-11-30 4:56 AM
Everything is in the title, my screen has 4bit per pixel and the keyboard example supports a minimum of 8bits color depth. Also the minimum resolution is 480x272 while my screen is smaller (320x240).
Thank you for your answer
Augustin
Options
2021-11-30 5:42 AM
Everything is in the title = example
Example codes is example and not custom code, this is your job maybe.
And for your question generate example code for 8bits and try it switch to 4 and change resolution, but 4 bit is only for custom LCD interfaces .
Maybe good start is try change in simulator
