Timer Interrupts prevent program from entering loop
Options
2014-07-31 1:05 PM
Posted on July 31, 2014 at 22:05
Hi everybody,
I'm using TIM1 to output pwm signal at 50kHz. I have a deal loop while(1) and some code inside the dead loop at the end of my program. If I setup and enable a timer1 interrupt, for example TIM1 Update Interrupt, the loop will never be entered and the code inside the loop will never be executed. I have cleared the interrupt pending bit in the interrupt, and the code inside the interrupt will not take a long time to execute, so it should be finished before the next interrupt.I really appreciate your help, thank you!
1 REPLY 1
Options
2014-07-31 1:16 PM
Posted on July 31, 2014 at 22:16
CPU/NVIC seem to disagree.
Use a Debugger, and figure out where the processor is executing code.
