TIM8 PWM Issue
officialkesh
Posted on March 31, 2016 at 15:49
Hello ,
I have config to TIM8 to generate 12 MHz clock signal  on PC8 using Timer8 Channel . For this I have configured as per below . When I checked on DSO , I am not getting any signal . What could be the reason for this ?
int main(void)
             /* TIM Configuration */
            TIM_Config();
  /* TIM clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM8, ENABLE);
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 6 ;       //for 2.048 MHz ---> use 40;
  TIM_TimeBaseInit(TIM8, &TIM_TimeBaseStructure);
  /* PWM1 Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OC3Init(TIM8, &TIM_OCInitStructure);
  TIM_OC3PreloadConfig(TIM8, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM8, ENABLE);
  TIM_CtrlPWMOutputs(TIM8, ENABLE);
  /* TIM8 enable counter */
  TIM_Cmd(TIM8, ENABLE);
  while (1){}
void TIM_Config(void)
  /* GPIOC and GPIOB clock enable */
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC , ENABLE);
  /* GPIOC Configuration */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 ;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
  /* Connect TIM8 pins to AF2 */
  GPIO_PinAFConfig(GPIOC, GPIO_PinSource8, GPIO_AF_TIM8);
#output #timer #pwm #stm32f4 #discovery
9 REPLIES 9
Posted on March 31, 2016 at 17:09
int main(void)
TIM_Config();
TIM_TimeBaseStructure.TIM_Period = (SystemCoreClock / 12000000) - 1; // 12 MHz
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
/* PWM1 Mode configuration: Channel3 */
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disble;
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Reset;
while (1){}
GPIO_PinAFConfig(GPIOC, GPIO_PinSource8, GPIO_AF_TIM8); // PC8 TIM8_CH3
officialkesh
Posted on April 01, 2016 at 07:46
Clive1 ,
Thanks for reply but I am not getting output signal on PC8 .
(1) I have verified  - PC8 is only configured TIM8 , Channel 3 in our code .
(2) What else could be reason for not getting output signal ?
Posted on April 01, 2016 at 19:14
Seemed to be viable here, I cleaned it up a little more and just bench tested this to confirm I can see 6 MHz (12 MHz toggle rate). If you don't check you are look at the right pin, or that there isn't something else going.
/* GPIOC clock enable */
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_25MHz; // 2,25,50, or 100
int main(void)
TIM_OCInitTypeDef TIM_OCInitStructure;
TIM_Config();
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle; // 6 MHz output
TIM_OCInitStructure.TIM_Pulse = 0;
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable;
while (1){}
officialkesh
Posted on April 04, 2016 at 07:57
clive1 ,
Scope is connected at proper MCU pin only .Need help further from your side . I have attached system_stm32f4xx.c and startup_stm32f4xx.s file .
Please give a one look and let me know what could be wrong with this set up .
________________
Attachments :
startup_stm32f4xx.s : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hzo3&d=%2Fa%2F0X0000000bbl%2FWWcIo.34SJ.IvYoFotDjaTwV83X_lxkrMHCtP40_04E&asPdf=false
system_stm32f4xx.c : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0dZ&d=%2Fa%2F0X0000000bbj%2FeNB2mWzRvKcYxxLpNeeO00zNveOnGvJ9t7n6qjYImNc&asPdf=false
Posted on April 04, 2016 at 12:30
Confirm that the code is running in a debugger. I tested functionality on STM32F4-DISCO
officialkesh
Posted on April 06, 2016 at 07:38
clive1 ,
In TIM_OC3Init() ,
/* Set the Capture Compare Register value */
 TIMx->CCR3 = TIM_OCInitStruct->TIM_Pulse;  line was creating issue .
So that CCR3 has initialized to some other value . After this if we assign value less than 3000 ,timer clock was not generating .
Fills each TIM_OCInitStruct member with its default value.
TIM_OCStructInit(TIM_OCInitTypeDef* TIM_OCInitStruct) needs to used before TIM_OC3Init() API .
The code that you have given was working with Keil IDE while it was not working with gcc tool-chain.
Any idea about this ?
- Pinkesh
Walid FTITI_O
Senior II
Posted on April 06, 2016 at 15:37
Hi pinkesh,
Please, give us more details about the device/hardware your using , the system clock configuration ...
-Hannibal-
Walid FTITI_O
Senior II
Posted on April 06, 2016 at 16:02
Hi pinkesh,
Try to copy and paste code in the main.c file of a template project in the STM32 standard library and it will work fine ( I have tested it with ST' gcc compiler system workbench SW4STM32). Maybe you have some extra code lines that makes problem with gcc.
-Hannibal-
Posted on April 06, 2016 at 17:06
I don't know, and really can't throw resources at it, it works here, the structures are fully initialized. Perhaps you can use PWM mode, and program with a 50/50 duty?
What version of GNU/GCC, some have given me headaches in the past (4.9) where viable code has been broken by the code generator/optimizer.
