the I2c of STM32F100C8T6B don't work
Options
2013-11-11 2:07 AM
Posted on November 11, 2013 at 11:07
we are trying to make a communication between the Mc and the Accelerometer
I see that the clock and data don't work right as on the scope I see the data and clock transitions are making together in the same time while the data must be settled before the rise edge of the clock attached image from the scope to the signal also I tried to make I22 using bit banging but the rise time and fall time of the port is 20Micro second which is exceed the max rise and fall time how to make this time less than 300 nano second
1 REPLY 1
Options
2013-11-12 8:29 AM
Posted on November 12, 2013 at 17:29
The attached image looks ok to me but there is no acknowledge from the slave.
Maybe you use wrong address or maybe the slave doesn't support write operation.
