SWV Trace Data Transfer Speed
TonyFauci
How many samples of a uint32_t can trace log in one second, when trace is set to 2MHz using stlinkv2?
An upper bound is at 62.5 kHz just based on 2MHz/32. Actual number will be less and will depend on how efficient your code is.
No doubt this is the underlying issue in your other thread:
https://community.st.com/t5/stm32-mcus-products/adc-sample-rate/td-p/589768
