Store values in internal flash
GauravK
Can variable values be stored in some fixed addresses of internal flash and retrieved from them after reset?
is there any example for same.
@Uwe Bonnes wrote:
You can write to erased memory cells.
@GauravK for more on this, see:
https://community.st.com/t5/stm32-mcus-products/flash-write-versus-erase-cycles/m-p/665631/highlight/true#M241948
and follow the link.
6 REPLIES 6
Uwe Bonnes
Chief
You can write to erased memory cells. This must happen in chunks, e.g. 256 bits on H7 and down to single bytes on some older families. If the retrieved value needs to be reporgrammed later, look for EPROM emulation.
Andrew Neil
As @Uwe Bonnes suggested, what you're looking for is:
Application note AN4894How to use EEPROM emulation on STM32 MCUs:
https://www.st.com/resource/en/application_note/an4894-how-to-use-eeprom-emulation-on-stm32-mcus-stmicroelectronics.pdf
and the X-CUBE-EEPROM EEPROM emulation expansion software for STM32Cube:
https://www.st.com/en/embedded-software/x-cube-eeprom.html
EDIT:
Older stuff for F4:
AN3969: EEPROM emulation in STM32F40x/STM32F41x microcontrollers
https://www.st.com/content/ccc/resource/technical/document/application_note/ec/dd/8e/a8/39/49/4f/e5/DM00036065.pdf/files/DM00036065.pdf/jcr:content/translations/en.DM00036065.pdf
See also:
https://www.st.com/en/embedded-software/stsw-stm32066.html
https://community.st.com/s/question/0D50X00009XkhQn/stm32f4-eeprom-emulation-hal-library
I will be checking and get back if needed
Akuma.6
I am working on STM32G0 series and trying to save the records (120bytes each record) into internal mcu flash memory location and when it required will read the read the stored records and do our operations.
Please let us know the logic.
Kumar
See the links posted earlier!
Some more info here - including links to some other implementations:
https://community.st.com/t5/stm32-mcus-embedded-software/eeprom-emulation-virtual-addresses/m-p/675788
