Store text file in stm32 flash
sne_123
How can we store a text file into stm32f103 flash memory and read its contents??
5 REPLIES 5
Ozone
Principal III
Define "read its contents".
You can embed the text as constant string/data into the source code.
You can implement a file system (like FatFS) to access a portion of the internal flash.
sorry but I dint get what you said. How to embed the text as constant string/data into source code???
Also I don't want to implement FatFs . Is there any other way??
static const char *some_text = \
    "Hello world\r\n" \
    "Line 2\r\n" \
    "Line 3\r\n";
One could also use a simple tool to convert a file into a .H file you could include into your project.
A more complex tools could perhaps that the file and create an object file the linker to pull in.​
