2017-05-29 01:26 AM
I faced problem when I tried to generate sine using Matlab Embedded coder as it is appear with normal format without using ARM instructions. I installed ARM CORTEX M through matlab package installer but it didn't appear in the replacement functions menu. any body can help as my code calculate a lot of sine cosine operations and the execution time is too big!
Thanks in advance
2017-06-02 08:49 AM
really appreciate you quick response. I will try to check all notes
thanks a lot
2017-06-02 08:51 AM
I didn't activate and interrupt routines yet. Only the DMA for the ADC as I am measuring 8 channels
