STM32L4 & CubeMX 4.25 clocksettings failure
taraben
Posted on April 26, 2018 at 19:04
Hello All,
I am using STM32L486RGT, CubeMX 4.25 STM32L4 lib 1.11.
At the STM32 I have a 16MHz crystall connected.
Now I run into problems setting up the clocktree. It works under certain combinations but not under the ones I want.
I want to use the 16MHz crystal, HSE, PLL, USB and CPU running at 64MHz.
not working: 16MHz Crystal, PLLSource:HSE, PLLM:1, PLLN:8, PLLR:2, Sysclock:64MHz, PLLSAI1N:12, PLLSAI1Q:4, USB:PLLSAI1Q:48MHz
working: switching the PLL source to HSI
I tried also with Nucleo Board STM32L452 and found the combination does initially does not work.
I put an 16MHz crystal to the board.
not working: as above, plus USB, PLLSAI1N:2, PLLSAI1Q:4, USB:PLLSAI1Q:48MHz
On all examples: AHBPrescalers are 1 so all peripheral/core/sysclock clocks are 64MHz
Here is the example SysClock Init from the generated not working sample:
the failing function is:
Can anyone confirm those problems?
Regards, Adib.
  * @retval None
void SystemClock_Config(void)
  RCC_PeriphCLKInitTypeDef PeriphClkInit;
    /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.PLL.PLLN = 8;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV7;
  RCC_OscInitStruct.PLL.PLLQ = RCC_PLLQ_DIV2;
  RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_3) != HAL_OK)
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1|RCC_PERIPHCLK_USART3
                              |RCC_PERIPHCLK_LPUART1|RCC_PERIPHCLK_I2C1
                              |RCC_PERIPHCLK_USB|RCC_PERIPHCLK_ADC;
  PeriphClkInit.Usart1ClockSelection = RCC_USART1CLKSOURCE_PCLK2;
  PeriphClkInit.Usart3ClockSelection = RCC_USART3CLKSOURCE_PCLK1;
  PeriphClkInit.Lpuart1ClockSelection = RCC_LPUART1CLKSOURCE_PCLK1;
  PeriphClkInit.I2c1ClockSelection = RCC_I2C1CLKSOURCE_PCLK1;
  PeriphClkInit.AdcClockSelection = RCC_ADCCLKSOURCE_SYSCLK;
  PeriphClkInit.UsbClockSelection = RCC_USBCLKSOURCE_PLLSAI1;
  PeriphClkInit.PLLSAI1.PLLSAI1Source = RCC_PLLSOURCE_HSE;
  PeriphClkInit.PLLSAI1.PLLSAI1M = 1;
  PeriphClkInit.PLLSAI1.PLLSAI1N = 12;
  PeriphClkInit.PLLSAI1.PLLSAI1P = RCC_PLLP_DIV7;
  PeriphClkInit.PLLSAI1.PLLSAI1Q = RCC_PLLQ_DIV4;
  PeriphClkInit.PLLSAI1.PLLSAI1R = RCC_PLLR_DIV8;
  PeriphClkInit.PLLSAI1.PLLSAI1ClockOut = RCC_PLLSAI1_48M2CLK;
  if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
    /**Configure the main internal regulator output voltage
  if (HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1) != HAL_OK)
    /**Configure the Systick interrupt time
17 REPLIES 17
Posted on May 29, 2018 at 14:32
maybe you need a different clock frequency, what is the exact issue ?
CubeMx 4.22.1
shows everything you want;
PLLM 1   x8   /2 = 64mhz /1 Hclk =64MHz
USB clock source is PLLSAI1Q
which is x12  /4
Posted on May 29, 2018 at 15:24
the IOC file is in the original posts section. sam2_goware.ioc.
My board is based on STM32L486RGT7. Crystal frequency is 16MHz. USB is connected.
For test purposes I ususaly use the Nucleo-L476RG board (but that has different crystal).
The problem is not board specific: the code stucks in SystemClock_Config() and runs into the Error handler.
Adib.
Posted on May 29, 2018 at 16:27
it gets stuck here ?
where did you set PLLM as /1 ?
where did you set AHB Prescaler as /1 ?
why is   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;  ?  HSE ?
did you enable the CSS ? should you ?
Clive ?
Posted on May 29, 2018 at 16:37
Does the code show a PLLM setting, or not?
Make sure to clear the auto/local declaration on the stack.
Follow the error path backward to understand where in the source it is triggered.
Posted on May 29, 2018 at 16:39
Not describing PLLM parameter?
Consider RCC_OscInitTypeDef RCC_OscInitStruct = {0}; so that initial values are clearly defined and not subject to noise from stack.
It probably throws an error and then gets stuck in the Error_Handler(), going to have to work backward, through code to determine cause. You have the source, you have a debugger, shouldn't take too long to pinpoint the cause/reason for the error.
Posted on May 29, 2018 at 17:08
can you to single step inside HAL_RCC_OscConfig,
which line causes the problem ?
Posted on May 29, 2018 at 17:11
The original post was too long to process during our migration. Please click on the provided URL to read the original post. https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I6v9&d=%2Fa%2F0X0000000by1%2F0BEBHQCfglgh98oUcc.WV2fQl.PGff.fJT8G1.Q2s.I&asPdf=false
Posted on May 29, 2018 at 19:28
  RCC_PeriphCLKInitTypeDef PeriphClkInit = {0};
    /**Initializes the CPU, AHB and APB buses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 1;
  RCC_OscInitStruct.PLL.PLLN = 12;
  RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV4;
Check obvious things like HSE ticking, and PLL parameters not exceeded
