STM32L1xx ADC EOC when using DMA
Options
‎2016-07-20 6:31 AM
Posted on July 20, 2016 at 15:31
I use STM32L1xx ADC in scan mode with DMA with these settings: ADC_CR1_SCAN set ADC_CR2_CONT cleared ADC_CR2_DDS and ADC_CR2_DMA set ADC_CR2_EOCS cleared I scan 4 channels after trigerering with ADC_CR2_SWSTART. Next scan is also started by just setting ADC_CR2_SWSTART. Should I get ADC_SR_EOC set after the last conversion of the scan is done and data are stored in memory? For me it remains cleared. How else can I determine end of scan? Thanks Martin
4 REPLIES 4
Options
‎2016-07-20 6:44 AM
Posted on July 20, 2016 at 15:44
Wouldn't the DMA reading the ADC->DR be expected to clear it?
Why can't you use the DMA TC or HT to signal the completion of all conversions?
Options
‎2016-07-26 12:02 AM
Posted on July 26, 2016 at 09:02
Hi Clive,
sorry for the delay... > Wouldn't the DMA reading the ADC->DR be expected to clear it? I read the ref manual up and down but couldn't find a clear statement on this. It says that EOC is cleared by reading ADC->DR but not if this is true also for using DMA. > Why can't you use the DMA TC or HT to signal the completion of all conversions? That is a good idea, I will try it. Thanks MartinOptions
‎2016-07-26 3:05 AM
Posted on July 26, 2016 at 12:05
Ok, I tried it. Using DMA_ISR.TCIFx works fine.
MartinOptions
‎2016-07-26 4:36 AM
Posted on July 26, 2016 at 13:36
In IC Design one wants to do things in the least complicated and convoluted manner possible. The peripheral does not differentiate the source of bus interactions, so a read action on an address (ADC->DR) is going to behave materially the same whether it comes from the CPU or DMA unit.
