STM32L100C6 Port H missing in Datasheet memory map
at1
Posted on February 28, 2014 at 11:04
I am missing Port H in the datasheet's memory map. Is it at 0x40021400?
https://my.st.com/st-extranet-web-active/static/active/en/resource/technical/document/datasheet/DM00078075.pdf
Thanks!
Alex
#stm32l-port-h
10 REPLIES 10
chen
Posted on February 28, 2014 at 15:07
Hi
OK, try the reference manual :
http://www.st.com/web/en/resource/technical/document/reference_manual/CD00240193.pdf
Looks like you are right, the datasheet omits the fact that you can have OSC_IN/OUT as PH0 and PH1
Looking more closely at the pin map for UFQFPN48, it looks like I was wrong about the
use of port C.
It only shows PortA and PortB
It looks like the 5 bits are part of the PH0 and PH1
