STM32L083RBTx unexpected periodic reset
‎2022-03-14 8:42 AM
I can see weird behaviour on my STM32L083RBT6. Do not know where to start - I will try:
- When I run my app with Window WD - everything works fine
- When I run my app with Window WD disabled - not every start of my app (power on by inserting battery) starts up corectly - it means the app remains stuck in unknown place (in time < 100 ms after power on)
- When I continue to toogle battery connecting (power on -> power off), so about after 20 cycles the mcu always starts up correctly but after about 500 ms the mcu always resets -> then starts up -> resets and again and again with period about 500 ms - from this moment it looks like the mcu is corrupted - Nothing like reflashing app (with or without WD) can save the mcu. In this state I tried to debug why the mcu resets - by reading the RCC->CSR register - but there is always bunch of set bits (WWDGRSTF, IWDRSTF, PORRSTF, PINRSTF, SFTRSTF) - so this feature probably does not work!
No voltage spikes captured on power pins during connecting and unconnecting battery.
I will be very grateful for any help.
- Labels:
STM32L0 Series
‎2022-03-17 1:58 PM
‎2022-03-21 2:28 AM
So now It is clear. I had unchecked WDG_SW - it means the IWDG was activated by harware and this is why the reset occured.
What I do not understand is why this bit was unchecked.
‎2022-03-21 5:54 AM
If IWDG_SW is unchecked, IWDG is enabled automatically by hardware and is causing your reset, as suspected in the very first reply to your post.
‎2022-03-21 6:40 AM
Yes, Thank you very much. Now I understand it. The question fro me is why this bit was unchecked...
- « Previous
- 1
- 2
- Next »
