2016-03-23 7:11 AM
I'd like to monitor battery voltage (V~8volts) using comparator and voltage devider with two resistors (1-10M). Coud you please specify analog comparator input impedance, so i can select appropriate resistor value. I'd like to minimize ground current throught divider. Thanks! #stm32l1 #comparator2016-03-23 8:30 AM
Whit succes i use 5M impadance devider for comparator. Check in datasheet input leakage current.
2016-03-24 2:13 AM
Thank you for reply, 5M is ok
