stm32l-discovery weird blinking on LD1
Options
2014-03-12 3:46 PM
Posted on March 12, 2014 at 23:46
Hi all,
I have a question regarding to LD1 COM LED of STM32L Discovery board.Fromhttp://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00027954.pdf
, it mentioned LD1 COM turns green to indicate that communications are in progress between the PC and the ST-LINK/V2. And normally it should be a red as default status. However, what does the blinking red indicate?With the same code, I saw this situation sometimes, but sometimes it just works fine. I always need to plug and unplug my USB cable until it functions normally...... Does anyone have any idea?Could it be caused by the insufficient current of my USB hub? Otherwise I couldn't think of a reasonable answer.
Thanks,
Shan
Options
2014-03-12 6:20 PM
Posted on March 13, 2014 at 02:20
So power the board with a bench supply, and see if that helps. Roll-back the firmware on the ST-LINK if you updated it prior to the issue. Or try a different board
[DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/stm32l-discovery%20weird%20blinking%20on%20LD1&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B&TopicsView=https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/AllItems.aspx¤tviews=20]Duplicative Thread
