STM32L Discovery Board - OPAMP question
Options
2014-12-05 2:10 AM
Posted on December 05, 2014 at 11:10
I have a question about the OPAMPs present in the ucontroller.
According to STM32L1XX.H 3 OPAMPS are available that can be used by driving the inverting/non-inverting input and output to different pins of the board by some switches.However it is not clear what switches connect to what pins on the board. Is there any picture that explains this?Are the power supply of the OPAMPs V- = GND and V+ = 3V ?
Options
2014-12-16 4:53 AM
Posted on December 16, 2014 at 13:53
Hi Marco,
You have to check the datasheet of the used MCU (Ex:http://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/CD00277537.pdf
)-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
