STM32H7 Max UART Baudrate
‎2017-11-24 7:15 AM
I tried to figure out the specification of the max. UART baudrate for the SM32H7 series (@ 400MHz system clock).
The data sheet says 12.5 MBit.
Does this apply to all UART ports or only selected ones?
I need 8 MBits @ 16x oversampling and 6 MBits @ 8x oversampling.
Are these baudrates possible?
Best regards,
Holger
‎2017-11-24 8:33 AM
RM0433 table 51 states the maximum peripheral clock. For all U(S)ART it is 100 MHz. That means 12.5 MBaud @ 8 oversampling and 6.25 at 16 oversampling. 8 x 16 in your question above needs 128 MHz peripheral clock, beyond the specs. Maybe overclocking the uart peripheral clock can be an option, if you dare.
B.t.w, I miss the spec for the maximum peripheral clock frequency in the datasheet and in Stcube!
‎2017-11-24 9:00 AM
The choice of dividers in the STM32 designs tends to work against you, especially at higher/maximal rates. These rates are also rather high for async comms, sure you can't use a better protocol or something synchronous? The STM32 USART designs also lack any FIFO, you might be better considering and external part optimized for such rates and attached to the FSMC
‎2017-11-24 1:38 PM
Ths STM33H7 Usart _has_ a FIFO
‎2017-11-24 2:42 PM
Ok, yes seems to have 16 word RX and TX.
‎2024-11-25 1:24 AM
You can use up to 125MHz clock source to USART peripherals on H7 if you use CubeMX to configure the clock tree. Then the baudrate can be up to 125/8 or 125/16 depending on the oversampling configurations. But ST HAL driver will stop you from using baudrate higher then 12.5M if assert_param is enabled.
