2020-07-03 8:12 AM
Are there some working hrtimer examples for STM32H7 floating around?
2020-07-16 1:59 AM
I confirm here is no DLL on the H7 series. You can check this with the oscilloscope: you'll see the output dithering, with 2 edges 2.5ns apart.
On a device with the DLL (F3, G4), you wouldn't see any dithering on the edge.
The reason why we cut this out of the spec are the following:
Best regards,
Vincent
