STM32G4 - Run after programming
Atzosskin
Hello I hope you can help.
We have developed a production programming solution for the range of STM32G474 devices which uses our own hardware controller interface.
Is it possible to replicate the "run after programming" --go command externally?
(eg, without using the STM32CubeProgrammer CLI.exe)
As currently the boards do not boot after configuration.
Kind regards
Atz.
Uwe Bonnes
Chief
Describe your setup better. Does the board run a bootloader or do you programm via SWD/Jtag. In the first case, your own bootloader needs ti implement som "go" command. With SWD/JTAG a reset, even sent via SWD/JTAG wi help.
