STM32F76 RMII Errata: Any hack/workaround
Uwe Bonnes
Chief
Posted on October 20, 2016 at 11:05
Despite several promises to keep us informed about the findings around the error with RMII in F76, only ''ask your FAE'' was posted here. Now silently Rev. 3 of the F76 errata appeared, stating ''No workaround''.
Does anybody have a hack to work somehow reliable with RMII on F76, as on the Nucleo-F769?
B.t.w.: It is no more possible to reply to the threads around ETH on F76 that were posted not even  a month ago. Trying to reply, ''404'' is received as answer. It is not good, if people bring up really old threads, but not even a month is a time span to short i.m.h.o.
waclawek.jan
Posted on October 20, 2016 at 11:34
I've just [DEAD LINK /public/STe2ecommunities/mcu/Lists/STM32Discovery/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/STM32Discovery/Stm32F767%20Nucleo%20Ethernet%20does%20not%20always%20start&FolderCTID=0x01200200770978C69A1141439FE559EB459D75800084C20D8867EAD444A5987D47BE638E0F&currentviews=94]succeeded to do so. The 404 might've been one of the many of this forum software's quirks.
Amel NASRI
Posted on October 20, 2016 at 12:43
We confirm the Ethernet limitations as described in
http://www.st.com/content/ccc/resource/technical/document/errata_sheet/group0/23/a6/11/0b/30/24/46/a5/DM00257543/files/DM00257543.pdf/jcr:content/translations/en.DM00257543.pdf
We would like to inform you that a new device revision will be available to fix these limitations.
For more details, please contact your FAE or distributor.
-STM32 Forums Moderator
Amel NASRI
Posted on October 26, 2016 at 18:16
The limitation ''Ethernet erroneous data received in RMII configuration'' is fixed in Revision Z of the STM32F76xxx and STM32F77xxx (see
