STM32F4XX RTC calendar can not be configured
sanmingx
Posted on May 01, 2015 at 01:45
When system boots up, RTC is initialized and could be configured with success, but any calendar configuration afterward will always fail with ''  if (RTC_EnterInitMode() == ERROR)'' in RTC_SetTime() standard API.
When system boots up, below code is called
void Rtc::open()
 // Enable the Power Controller APB1
 // interface clock
 /* Enable PWR peripheral clock */
 uint32_t status;
 uint8_t stat = 1;
 RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE); /* Allow access to BKP Domain */
 PWR_BackupAccessCmd(ENABLE);
 status = RTC_ReadBackupRegister(RTC_BKP_DR19);
 // Power up and wait until LSI is ready
 RCC_LSICmd(ENABLE);
 while(RCC_GetFlagStatus(RCC_FLAG_LSIRDY) == RESET)
 // Select the RTC Clock Source
 RCC_RTCCLKConfig(RCC_RTCCLKSource_LSI);
 // Enable the RTC Clock
 RCC_RTCCLKCmd(ENABLE);
 RTC_WaitForSynchro();
 //RTC_WriteBackupRegister(RTC_BKP_DR0, 0x32F2);
 RTC_WriteBackupRegister(RTC_BKP_DR19, 0x1234);
 RTC_ClearITPendingBit(RTC_IT_WUT);
 EXTI_ClearITPendingBit(EXTI_Line22);
//------------------------------------ Configure calendar ---------------
void Rtc::write(TimeDateStruct idateTime)
     RTC_SetTime(RTC_Format_BIN, &idateTime.time);
as you can see, RTC_SetTime is standard API from lib as below, it stops on line ''if (RTC_EnterInitMode() == ERROR)'' of ''INITF'' flag timeout.
Please help this issue, thanks
ErrorStatus RTC_SetTime(uint32_t RTC_Format, RTC_TimeTypeDef* RTC_TimeStruct)
  uint32_t tmpreg = 0;
  ErrorStatus status = ERROR;
  /* Check the parameters */
  assert_param(IS_RTC_FORMAT(RTC_Format));
  if (RTC_Format == RTC_Format_BIN)
    if ((RTC->CR & RTC_CR_FMT) != (uint32_t)RESET)
      assert_param(IS_RTC_HOUR12(RTC_TimeStruct->RTC_Hours));
      assert_param(IS_RTC_H12(RTC_TimeStruct->RTC_H12));
    else
      RTC_TimeStruct->RTC_H12 = 0x00;
      assert_param(IS_RTC_HOUR24(RTC_TimeStruct->RTC_Hours));
    assert_param(IS_RTC_MINUTES(RTC_TimeStruct->RTC_Minutes));
    assert_param(IS_RTC_SECONDS(RTC_TimeStruct->RTC_Seconds));
  else
      tmpreg = RTC_Bcd2ToByte(RTC_TimeStruct->RTC_Hours);
      assert_param(IS_RTC_HOUR12(tmpreg));
    else
      assert_param(IS_RTC_HOUR24(RTC_Bcd2ToByte(RTC_TimeStruct->RTC_Hours)));
    assert_param(IS_RTC_MINUTES(RTC_Bcd2ToByte(RTC_TimeStruct->RTC_Minutes)));
    assert_param(IS_RTC_SECONDS(RTC_Bcd2ToByte(RTC_TimeStruct->RTC_Seconds)));
  /* Check the input parameters format */
  if (RTC_Format != RTC_Format_BIN)
    tmpreg = (((uint32_t)(RTC_TimeStruct->RTC_Hours) << 16) | \
             ((uint32_t)(RTC_TimeStruct->RTC_Minutes) << 8) | \
             ((uint32_t)RTC_TimeStruct->RTC_Seconds) | \
             ((uint32_t)(RTC_TimeStruct->RTC_H12) << 16));
  else
    tmpreg = (uint32_t)(((uint32_t)RTC_ByteToBcd2(RTC_TimeStruct->RTC_Hours) << 16) | \
                   ((uint32_t)RTC_ByteToBcd2(RTC_TimeStruct->RTC_Minutes) << 8) | \
                   ((uint32_t)RTC_ByteToBcd2(RTC_TimeStruct->RTC_Seconds)) | \
                   (((uint32_t)RTC_TimeStruct->RTC_H12) << 16));
  /* Disable the write protection for RTC registers */
  RTC->WPR = 0xCA;
  RTC->WPR = 0x53;
  /* Set Initialization mode */
    status = ERROR;
  else
    /* Set the RTC_TR register */
    RTC->TR = (uint32_t)(tmpreg & RTC_TR_RESERVED_MASK);
    /* Exit Initialization mode */
    RTC_ExitInitMode();
    /* If  RTC_CR_BYPSHAD bit = 0, wait for synchro else this check is not needed */
    if ((RTC->CR & RTC_CR_BYPSHAD) == RESET)
    if(RTC_WaitForSynchro() == ERROR)
      status = ERROR;
    else
      status = SUCCESS;
    else
      status = SUCCESS;
  /* Enable the write protection for RTC registers */
  RTC->WPR = 0xFF;
  return status;
4 REPLIES 4
Posted on May 01, 2015 at 03:22
Make sure you reset the RTC if it gets into an unknown state, and that clocks are enabled.
[DEAD LINK /public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Need%20help%20initializing%20RTC%20on%20STM32F407&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B&currentviews=3345]https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=%2Fpublic%2FSTe2ecommunities%2Fmcu%2FLists%2Fcortex_mx_stm32%2FNeed%20help%20initializing%20RTC%20on%20STM32F407&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=3345
sanmingx
Posted on May 05, 2015 at 20:48
Hello, Clivel
I did try to reset the RTC by calling ''RCC_BackupResetCmd(ENABLE);
RCC_BackupResetCmd(DISABLE)'' followed when ''
RTC_EnterInitMode() == ERROR'' occurred, it seemed not fix my issue at all. Is it the right way to reset RTC?
the clock is sourced with LSI, with no external battery, the Vbatt is 3.3 V, I guess it is good.
engenharia2
Posted on January 14, 2016 at 15:12
Hi xiang.sanming, I have the same problem using the HAL Library. Do you got a solution to fix this problem? Thank you!
Posted on January 14, 2016 at 19:19
I'm not sure someone who participated for 2 posts, 8 months ago, using the SPL, is going to be at all useful with your HAL issues.
See if there is anything useful you can gleen from the cited thread.
