STM32F4DISCOVERY using DAC pins A4 & A5 without the codec
‎2013-04-10 6:44 AM
I'm using a STM32F4DISCOVERY to program the firmware of my future board. I want to use the integrated 12 bit DAC of the board to generate analog simple signals on the A4 and A5 pins, but I don't want to use the external audio codec CS43L22 of the discovery board. On theSTM32F4DISCOVERY board A4 and A5 are connected to the LIS30 and the CS43L22 but I think it's OK to use these pins for generate analog signals. Am I right ? So I try to program with this code I found on a forum:
int
main(
void
DAC_InitTypeDef DAC_InitStructure;
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
/* Enable DAC and GPIOC clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOA, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC | RCC_APB1Periph_TIM2, ENABLE);
/* Configure PA.04/05 (DAC) as output -------------------------*/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* DAC channel1 Configuration */
DAC_InitStructure.DAC_Trigger = DAC_Trigger_None;
DAC_InitStructure.DAC_WaveGeneration = DAC_WaveGeneration_None;
DAC_InitStructure.DAC_OutputBuffer = DAC_OutputBuffer_Enable;
DAC_Init(DAC_Channel_2, &DAC_InitStructure);
/* Enable DAC Channel2: Once the DAC channel2 is enabled, PA.05 is
automatically connected to the DAC converter. */
DAC_Cmd(DAC_Channel_2, ENABLE);
while
(1)
int
i;
for
(i=0; i<4096; i++)
DAC_SetChannel2Data(DAC_Align_12b_R, i);
/* does not exit - kind of important */
return
(1);
This code works on STM32F3xx but there is some problems with STM32F4xxcompactibility. Line 8, ''RCC_APB2Periph_AFIO'' and ''RCC_APB2Periph_GPIOA'' are not declared in librairies.
Is anyone know what are the RCC_APB2Periph_AFIO andRCC_APB2Periph_GPIOA equivalent in STM32F4xx ? Thanks for your help !
note: I'm using the latest STM32F4xx librairies, but not thestm32f4_discovery librairy.
#dac #stm32f407 #stm32f4discovery
DAC
STM32F4 Series
‎2013-04-10 7:15 AM
There are parts of that which look
. SYSCFG is some what equivalent to AFIO, but irrelevant in this context. /* GPIOA Periph clock enable */ RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);Up vote any posts that you find helpful, it shows what's working..
‎2013-04-10 7:27 AM
Yes clive1, I think it comes from your code !
So I need to change:RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOA, ENABLE);
With:
Now I have no compilation errors, but I have nothing on PA5 and PA4...
‎2013-04-10 7:56 AM
Sorry, in fact it's working fine !
I can generate analog signals between 0V and 3V!The next step is to control a modular synth, I have to link an Opamp between PA5 and the modular synth.I found this ref, I think it's the perfect choice:http://www.st.com/web/catalog/sense_power/FM123/SC61/SS1614/PF65462?s_searchtype=partnumber
‎2013-04-11 8:05 AM
I have a new problem with the DAC...
I just try to put the code in .c .h files but now the two DAC are not working anymore... This is my init_DAC.c code:/* Use standard template */
#define USE_STDPERIPH_DRIVER
#define STM32F4XX
/* Includes */
#include ''stm32f4xx_rcc.h''
#include ''stm32f4xx_gpio.h''
#include ''stm32f4xx_dac.h''
#include ''stm32f4xx_tim.h''
void
DAC_Config(
void
/* GPIOD Periph clock enable */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
//RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOA, ENABLE);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
/* DAC channel1 & DAC_Channel_2 Configuration */
DAC_Init(DAC_Channel_1, &DAC_InitStructure);
/* Enable DAC Channel1 & Channel2: Once the DAC is enabled, PA.05 is
DAC_Cmd(DAC_Channel_1, ENABLE);
In main.c I call this function...
DAC_Config();
...and I gererate analog levels:
DAC_SetChannel1Data(DAC_Align_12b_R, 4095);
DAC_SetChannel2Data(DAC_Align_12b_R, 2095);
But no outputs on PA3 and PA4. If I replace
DAC_Config();
by the corresponding code of DAC_Config() it's working ! Do you have any idea ? Thanks !- Mark as New
‎2013-04-11 10:07 AM
Per STM32F2xx_StdPeriph_Lib_V1.1.0\Project\STM32F2xx_StdPeriph_Examples\DAC\DAC_SignalsGeneration (applicable to F4 too)
/* DMA1 clock and GPIOA clock enable (to be used with DAC) */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1 | RCC_AHB1Periph_GPIOA, ENABLE);
/* DAC Periph clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE);
/* DAC channel 1 & 2 (DAC_OUT1 = PA.4)(DAC_OUT2 = PA.5) configuration */
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
‎2013-04-12 5:34 AM
Thanks clive1, I think that improved my code, but I have still the same problem...
1) The DAC initialisation is in the file init_DAC.c that I call from main.c In this configuration the DAC outputs are not working, in fact, they are working 1 of ten times (other times the two outputs generates randomly 0V or 3V) 2) If I copy EXACTLY the code of the dac initialisation into main.c this is perfectly working ! This is init_DAC.c:/* Includes */
void
DAC_Config(
void
GPIO_InitTypeDef GPIO_InitStructure_DAC;
/* Enable DAC clock */
GPIO_InitStructure_DAC.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
GPIO_InitStructure_DAC.GPIO_Mode = GPIO_Mode_AN;
GPIO_InitStructure_DAC.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOA, &GPIO_InitStructure_DAC);
This is main.c:
/* Includes */
#include ''stm32f4xx_dma.h''
#include ''init_DAC.h''
int
main(
void
int
i;
DAC_Config();
while
(1)
for
(i=0; i<4095; i=i+5) DAC_SetChannel2Data(DAC_Align_12b_R, i);
for
(i=4095; i>0; i=i-8) DAC_SetChannel2Data(DAC_Align_12b_R, i);
return
(1);
‎2013-04-12 7:00 AM
Well that would be annoying, what tool chain are you using?
If I were perplexed I'd look at the assembler code generated by the two cases, and see if that shed any light on the situation.Up vote any posts that you find helpful, it shows what's working..
‎2013-04-12 7:46 AM
I'm using the yagarto toolchain (with Coocox IDE)...
I forgot to mention that the behaviour is random when I reset the discoveryboard too (with the RST button), not only when I program the flash.- Mark as New
‎2013-04-12 9:12 AM
:020000040800F2
:10000000000400209D010008730300086F0300082E
:1000100071030008F5010008DD040008000000007D
:10002000000000000000000000000000AD03000818
:10003000C9020008000000007903000889040008D4
:10004000C3010008C3010008C3010008C301000880
:10005000C3010008C3010008CB020008C301000867
:10006000C3010008C3010008C3010008C301000860
:10007000C3010008C3010008C3010008C301000850
:10008000C3010008C3010008C3010008C301000840
:10009000C3010008C3010008C3010008C301000830
:1000A000C3010008C3010008C3010008C301000820
:1000B000C3010008C3010008C3010008C301000810
:1000C000C3010008C3010008C3010008C301000800
:1000D000C3010008C3010008C3010008C3010008F0
:1000E000C3010008C301000877030008C30100082A
:1000F000C3010008C3010008C3010008C3010008D0
:10010000C3010008C3010008C3010008C3010008BF
:10011000C3010008C3010008C3010008C3010008AF
:10012000C3010008C3010008C3010008C30100089F
:10013000C3010008C3010008C3010008C30100088F
:10014000C3010008C3010008C301000875030008CB
:10015000C3010008C3010008C3010008C30100086F
:10016000C3010008C3010008C3010008C30100085F
:10017000C3010008C3010008C3010008C30100084F
:10018000C3010008C3010008DFF80CD000F020F81C
:1001900000480047130500080004002009480168D2
:1001A00041F470010160084880470848004700009A
:1001B000FEE7FEE7FEE7FEE7FEE7FEE7FEE7FEE717
:1001C000FEE7FEE788ED00E08D04000889010008E5
:1001D000064C074D06E0E06840F0010394E8070094
:1001E00098471034AC42F6D3FFF7D2FF4C05000815
:1001F0005C050008FEE70000044A01238340106804
:1002000009B1184300E09843106070470074004043
:1002100010B5012186B0084600F0B0F8012114485D
:1002200000F0ACF80121480700F0B4F83020049049
:1002300003208DF8140000248DF8174004A90D4800
:1002400000F044F80094019469461020039400F0F3
:1002500013F86946002000F00FF801211020FFF785
:10026000CBFF01210020FFF7C7FF06B010BD000043
:10027000010020000000024030B5084C236840F621
:10028000FE7282409343D1E900252A43D1E902510D
:100290000D432A4382401A43226030BD007400405F
:1002A000034A08B5104408300090016008BD000002
:1002B00000740040034A08B51044143000900160F7
:1002C00008BD00000074004070477047F0B500237F
:1002D000012403270D6804FA03F21540954242D128
:1002E000D0F800C05E0007FA06F52CEA050CC0F84D
:1002F00000C091F804C0D0F800E00CFA06FC4CEA0B
:100300000E0CC0F800C091F804C0BCF1010F02D07F
:10031000BCF1020F1FD1D0F808C02CEA050CC0F8C0
:1003200008C091F805C0D0F808E00CFA06FC4CEAC9
:100330000E0CC0F808C0D0F804C02CEA020CC0F8BB
:1003400004C0426891F806C00CFA03FC1FFA8CFC4A
:1003500042EA0C024260C268AA43C260CA79C56818
:10036000B2402A43C2605B1C102BB3D3F0BDFEE742
:10037000FEE770477047704770470000044A002945
:10038000116801D0014300E0814311607047000013
:1003900030380240044A0029116801D0014300E0CE
:1003A00081431160704700004038024070470000F0
:1003B0000CB500222E4901920092086840F480306A
:1003C00008604FF4A063086800F4003000900198C2
:1003D000401C0190009810B901989842F3D1086828
:1003E0008303244841D501220092224A38321368FF
:1003F00043F080531360204A136843F48043136032
:1004000002680260026842F400420260026842F43C
:10041000A0520260031F194A1A600A6842F08072F3
:100420000A600A689201FCD5154B40F205621A6019
:10043000026822F003020260026842F002020260D7
:100440000268C2F38102022AFAD1026822F4000291
:100450000260084A0B487C321060086840F08060F7
:10046000086008680001FCD50CBD0092EDE70000B3
:10047000003802400838024000700040085440072D
:10048000003C024000300050704700000F4810B59B
:10049000016841F0010101600C4A0021083211603D
:1004A00002680B4B1A400260031D0A4A1A60026878
:1004B00022F48022026005480C300160FFF778FFCB
:1004C00005494FF00060086010BD00000038024090
:1004D000FFFFF6FE1030002408ED00E0FEE702E02A
:1004E00008C8121F08C1002AFAD1704770470020BF
:1004F00001E001C1121F002AFBD1704708B54FF47B
:10050000FA700090411E0091002801D00846F9E7DA
:1005100008BDFFF77DFE40F6FF750024A1B2002064
:10052000FFF7C8FEFFF7EAFF641DAC42F6DB2C467E
:10053000A1B20020FFF7BEFEFFF7E0FF083C002C51
:10054000F6DC29460020FFF7ABFEE6E75C05000875
:0C0550000000002000040000EE04000881
:040000050800018965
:00000001FF
