STM32F469I Discovery - cannot flash demo hex file
- January 12, 2017
- 8 replies
- 2599 views
Posted on January 12, 2017 at 14:59
I'm trying to flash the demo hex file from STM32F469I-Discovery Kit. But STLink Utility fails when download the Firmware.
I've attached log Files.
Following Error Message occurs:
14:32:53 : Connection to device is lost: check power supply and debug connection.
14:32:53 : If the target is in low power mode, please enable 'Debug in Low Power mode' option from Target->settings menu.14:53:49 : Cannot save hex/srec file to bin fileIs there a problem when flashing the external NAND Flash?
Thank you.
Kind Regards
Andreas
