2016-03-20 11:51 PM
Hi, I want to ask you if it is possible using HAL to change usb format audio from 16bit to 24bit and vice versa. Now I can choose in windows between different frequencies of 16bit sampling, but if I change usb descriptor and add 24 bit sampling - windows doesn't see 24bit (only 16bit). If I set only 24 bit sampling windows see it. Please help me.
2016-03-21 03:18 AM
I solved the problem. I have to change Input Terminal in usb descriptor.
2016-03-21 06:18 AM
Hi ntow,
Thank you for your contribution and the experience sharing. -Hannibal-2016-06-01 06:06 AM
Hi, can you describe how to solve this problem?)
