2016-03-08 07:02 AM
2016-03-08 08:27 AM
Hello zudse.zeta,
The DCMI pins are disabled because they are already defined and used by other external components of the board.To have more idea about these components, you can refer to thehttp://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00039084.pdf
User Manual, precisely in the Table 6. STM32 pin description versus board functions.Best Regards-ForumSTM32-2016-03-08 08:35 AM
Perhaps you want to review how the
http://www.st.com/web/catalog/tools/FM146/CL1984/SC720/SS1462/PF255417?sc=stm32f4dis-expansion
camera was handled, should be code of that in SPL rather than CubeMX, but might provide insight.CubeMX is designed to recognize pin/peripheral combinations that clash, remove the settings/configurations that clash to access the DCMI pins and peripheral.
