STM32F407 GPIO not toggles on 168MHz SysClk
‎2015-10-16 2:31 AM
Good day,
I use CooCox 1.7.8 and STM32F4DISCOVERY as programmator. Problem is, that after re-configuring SysClk to PLL running on 168MHz (which is confirmed through observing 84MHz on MCO1 output) ToggleBit command produce no effect on LED's. If decrease SysClk to 42MHz, everything is working. Please see code below: ***#include ''stm32f4xx.h''
#include ''stm32f4xx_gpio.h'' </p>
</b>
#include ''stm32f4xx_rcc.h''
GPIO_InitTypeDef
GPIO_InitStruct;int i, k=0, l=0; </p>
</b>
int
main(
void
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE,
ENABLE
);GPIO_InitStruct.
GPIO_Pin
= GPIO_Pin_8|GPIO_Pin_10;
// we want to configure LED's: D1, D3
GPIO_InitStruct.
GPIO_Mode
GPIO_Mode_OUT
// we want it to be an OutputGPIO_InitStruct.
GPIO_Speed
GPIO_Speed_100MHz
//this sets the GPIO modules clock speedGPIO_InitStruct.
GPIO_OType
GPIO_OType_PP
// this sets the pin type to push / pull (as opposed to open drain)
GPIO_InitStruct.
GPIO_PuPd
GPIO_PuPd_NOPULL
// this disables the pull-down resistor GPIO_Init(GPIOE, &GPIO_InitStruct);
GPIO_SetBits(GPIOE, GPIO_Pin_8|GPIO_Pin_10);
// LED1, LED3 On
for
(i=0; i<50000; i++);
//Wait
GPIO_ResetBits(GPIOE, GPIO_Pin_8|GPIO_Pin_10);
// LED1, LED3 Off/* Output HSE clock on MCO1 pin(PA8) ****************************************/
/* Enable the GPIOA peripheral */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,
ENABLE
);/* Configure MCO1 pin(PA8) in alternate function */
GPIO_InitStruct.
GPIO_Pin
= GPIO_Pin_8;GPIO_InitStruct.
GPIO_Speed
GPIO_Speed_100MHz
;GPIO_InitStruct.
GPIO_Mode
GPIO_Mode_AF
;GPIO_InitStruct.
GPIO_OType
GPIO_OType_PP
;GPIO_InitStruct.
GPIO_PuPd
GPIO_PuPd_UP
;GPIO_Init(GPIOA, &GPIO_InitStruct);
/* (PLL_clock/2) selected to output on MCO1 pin (PA8)*/
RCC_MCO1Config(RCC_MCO1Source_PLLCLK, RCC_MCO1Div_2);
RCC_PLLConfig(RCC_PLLSource_HSI, 0x08, 0xA8, 0x02, 0x07);
//PLLM=8 (2MHz), PLLN=168 (336MHz), PLLP=2 (SYS=168), PLLQ=7 (USB=48)
RCC_PLLCmd(
ENABLE
//Enable PLL using HSI
while
(!RCC_GetFlagStatus(RCC_FLAG_PLLRDY));
//Wait till PLL frequency established (23) RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
//Choose PLL as SYSCLK
for
(i=0; i<16800; i++);
//Wait
while
(1){
GPIO_ToggleBits(GPIOE, GPIO_Pin_8|GPIO_Pin_10);
// LED1, LED3 On
for
(i=0; i<1680; i++);
//Wait GPIO_ToggleBits(GPIOE, GPIO_Pin_8|GPIO_Pin_10);
// LED1, LED3 On
for
(i=0; i<1680; i++);
//Wait }***
As well, under debugger last while(1) reach its end successfully
(using breakpoints) but after it hangs.
Thanks in advance,
Konstantin
‎2015-10-16 3:01 AM
Observe the LED pin with oscilloscope.
JW- Mark as New
‎2015-10-16 6:05 AM
‎2015-10-16 7:06 AM
Do you have the FLASH latency set properly?
JW- Mark as New
‎2015-10-16 8:19 AM
As Jan indicates there is the flash wait state setting, but also where the AHB/APB clocks are set, and enable the High Performance Power mode.
CooCox has this broken interpretation of the CMSIS requirement to call SystemInit() to set up the clocks prior to setting the C Environment up and calling main()Up vote any posts that you find helpful, it shows what's working..
‎2015-10-19 3:50 AM
Thanks everyone.
FLASH->
ACR
|= FLASH_ACR_LATENCY_5WS;solves problem.!!.
BR. K.As Jan indicates there is the flash wait state setting, but also where the AHB/APB clocks are set, and enable the High Performance Power mode.
