2014-11-17 3:44 AM
Hello.
I use software I2C for communication with DS1307 because hardware is using for other peripheral.This is working corectly without SystemInit();When I use SystemInit(); DS1307 not return ack. I set up same clock period in first and second case, LogicAnalyzer show correctly output signal, but DS1307 not return ack in second case.Where is a problem?
