[STM32F4-Discovery] UART4 Problem
‎2012-02-24 3:36 AM
Hi all,
I'm searching to get work my UART4 port on my Discovery. I used the USART HyperTerminal_Interrupt example on stdPerif_example and I adapted to DISCOVERY. I see by some LedOn on the program that UART is working and sending interrupt. I manage to have a virtual USB-UART port with UM232R Ftdi but on my Putty nothing appeared I post my code /* USARTx configuration ------------------------------------------------------*/ /* USARTx configured as follow: - BaudRate = 9600 baud - Word Length = 8 Bits - Two Stop Bit - Odd parity - Hardware flow control disabled (RTS and CTS signals) - Receive and transmit enabled */ USART_InitStructure.USART_BaudRate = 9600; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_2; USART_InitStructure.USART_Parity = USART_Parity_Odd; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; STM_EVAL_COMInit(&USART_InitStructure); Function void STM_EVAL_COMInit(USART_InitTypeDef* USART_InitStruct) { GPIO_InitTypeDef GPIO_InitStructure; /* Enable GPIO clock */ //RCC_AHB1PeriphClockCmd(UART4_TX_PIN | UART4_RX_PIN, ENABLE); RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC, ENABLE); //clock a PORTC RCC_APB1PeriphClockCmd(RCC_APB1Periph_UART4, ENABLE); //clock alla UART4! /* Connect PXx to USARTx_Tx*/ GPIO_PinAFConfig(GPIOC, GPIO_Pin_10, GPIO_AF_UART4); /* Connect PXx to USARTx_Rx*/ GPIO_PinAFConfig( GPIOC, GPIO_Pin_11, GPIO_AF_UART4); /* Configure USART Tx as alternate function */ GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOC, &GPIO_InitStructure); /* Configure USART Rx as alternate function */ GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; GPIO_Init(GPIOC, &GPIO_InitStructure); /* USART configuration */ USART_Init(UART4, USART_InitStruct); /* Enable USART */ USART_Cmd(UART4, ENABLE); } I also add void UART4_IRQHandler(void); to _it.h to manage interrupt _it.c void UART4_IRQHandler(void) { if(USART_GetITStatus(UART4, USART_IT_RXNE) != RESET) { GPIO_SetBits(GPIOD, GPIO_Pin_14); // accende led /* Read one byte from the receive data register */ RxBuffer[RxCounter++] = (USART_ReceiveData(UART4) & 0x7F); if(RxCounter == NbrOfDataToRead) { /* Disable the UART4 Receive interrupt */ USART_ITConfig(UART4, USART_IT_RXNE, DISABLE); } } if(USART_GetITStatus(UART4, USART_IT_TXE) != RESET) { GPIO_SetBits(GPIOD, GPIO_Pin_13); // accende led /* Write one byte to the transmit data register */ USART_SendData(UART4, TxBuffer[TxCounter++]); if(TxCounter == NbrOfDataToTransfer) { /* Disable the UART4 Transmit interrupt */ USART_ITConfig(UART4, USART_IT_TXE, DISABLE); } } } Where I'm failing? THanks #uart/usart-parity-and-wordlengt- Labels:
UART-USART
‎2012-02-24 4:07 AM
GPIO_PinAFConfig(GPIOC, GPIO_PinSource_10, GPIO_AF_UART4);
GPIO_PinAFConfig( GPIOC, GPIO_PinSource_11, GPIO_AF_UART4);Up vote any posts that you find helpful, it shows what's working..
‎2012-02-24 5:58 AM
YeP works!!!
Thanks clive1!!!! U save the daY!!! (to be precise is GPIO_PinAFConfig(GPIOC, GPIO_PinSource10, GPIO_AF_UART4); GPIO_PinAFConfig( GPIOC, GPIO_PinSource11, GPIO_AF_UART4); without underscore) I see by Putty some data steam appearing but It's not the welcome message... uint8_t TxBuffer[] = ''\n\rUSART Hyperterminal Interrupts Example: USART-Hyperterminal\ communication using Interrupt\n\r''; Is the problem that DATA is uint16 and data uint8??void USART_SendData ( * USARTx,
uint16_t Data
or have I to configure putty in another way? That's what I see: à øüpÿÿà pÇüà à þüüà à ðüà à ðü~üà ü~à üüà Çà ü~Àüà à ðà ðüüüüüðüà üÿüü~üüà à þüà üpÿÿà pÇüà þüüà à ðüà à ðü~üà ü~à üüà üüüü~Çü~Çüüðü~üüüüüüà ü~à üü~øüÇà ü~ÿà üà Çà ü~Àüà à ðà ðüüüüà ø translation ISO-8859-1:1998 (Latin-1, West Europe) Thanks in advance- Mark as New
‎2012-02-24 7:01 AM
Sorry working from memory. PinSource uses an index, Pin uses a mask.
You might want to check the ODD parity setting, that would give you weird characters if the terminal is configured for 8N1.Up vote any posts that you find helpful, it shows what's working..
‎2012-02-24 7:19 AM
no problem clive1 for pinsource
back to problem, If I try to send ''a'' (TXBuffer[]=''a'') the response to terminal is ü what's wrong? I double checked and my configuration is /* USARTx configured as follow: - BaudRate = 9600 baud - Word Length = 8 Bits - Two Stop Bit - Odd parity - Hardware flow control disabled (RTS and CTS signals) - Receive and transmit enabled I can't understand- Mark as New
‎2012-02-24 7:40 AM
then if I send ''ab'' the response is
üpÀü ?- Mark as New
‎2012-02-24 7:54 AM
If it's not the 8O2 rather than 8N1, then perhaps the baud rate is set up wrong.
Consider how the code is being compiled. The STM32F4-Discovery board has a different crystal speed for HSE than the library default. I think you want 8 MHz, not 25 MHz. Check the crystal speed in the IDE, and the value of HSE_VALUEUp vote any posts that you find helpful, it shows what's working..
‎2012-02-24 8:37 AM
thx clive1
I changed PLL_M value but the result is the same üpÀü @25Mhz üpÀü @8Mhz I don't know where else to look I'll send you my source files... I'll hope it's help.I'm using Atollic True Studio lite Thanks in advance ________________ Attachments : src.rar : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I03h&d=%2Fa%2F0X0000000bTS%2F9M3pHzW3WhVxeYiORQ3mhfylrOfc0VakkGoJvC5nmSg&asPdf=false- Mark as New
‎2012-02-24 7:54 PM
Well nothing looks to be hideously amiss, I guess at this point I'd be tempted to have it send a continuous stream of characters, 'U' being a particularly clever one, and measure/confirm the bit timing on a scope.
I might also try RealTerm, and try without parity.Up vote any posts that you find helpful, it shows what's working..
‎2012-02-27 2:23 AM
Dear Clive1,
I have performed the test you havesuggested
. I have tried with and without parity but nothing change... I post u some realTerm images (thanks for RT!!!) (->Can't upload images... I put on Attach) As u can see there is an ERROR bit! So I think that the problem is il my FTDI UM232r CHIP that can't handle the communication because the STM32 seems working good I post also a screenshot of PC10 pin of my oscilloscope I freeze the image of stream of U. It's seems work. The output values are: Vpeak-peak 3V Period 659us Freq 1,51 kHz baud= 8bit/2,5ms=3200 ( possible??) Is a problem that Vinput of 3V and not 3,3V for FTDI chip? Thanks again! ________________ Attachments : UART.rar : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I06L&d=%2Fa%2F0X0000000bTR%2F4z5H.V7ZA3AXpr57yQVcV_eoJyBqQk1ZwbqBiyaMod4&asPdf=false
