STM32F4 and double returning value divided by 10.
Bogdan
Posted on June 16, 2014 at 10:16
Hi guys, i recently started to work with orientations and quaternions.
Said to do a little math in paralel with my program with a excel spreadsheet.
I have the following q`s values
double q1=0.99551634;
double q2=-0.0699638;
double q3=-0.0396818;
double q4=-0.0497758;
char txt[10];
double qaa=2*q3*q4-2*q1*q2;
double qbb=2*q1*q1+2*q4*q4-1;
float qqq=atan2(qaa,qbb);
sprintf(pitch,''%f'',qqq );
UB_LCD_2x16_String(1,1,text);
With the given values for each q, the atan2 result is 0.144122 on my lcd display.
Doing the same math and the same values in a excel spreadsheet, the result is
1.426674134.
Tryied even with double for my qqq, but the result is the same.
I wonder why... ?
5 REPLIES 5
ivani
Posted on June 16, 2014 at 11:00
It probably should be:
sprintf(txt,''%f'',qqq );
And one more thought: Isn't the order of arguments in the Excel reversed versus C atan2()?
Trev
Posted on June 16, 2014 at 11:12
I'd use some brackets here to ensure it does what you expect (and allow us to know what you intended)
waclawek.jan
Posted on June 16, 2014 at 11:18
While spreadsheet calculators assume ATAN2(x, y), C has a different order of arguments, see C99 7.12.4.4
#include <math.h>
double atan2(double y, double x);
float atan2f(float y, float x);
long double atan2l(long double y, long double x);
zzdz2
Posted on June 16, 2014 at 11:25
Apparently the problem has nothing to do with STM32.
I just compiled your function on my pc and it prints 0.144122.
You would better ask on some excel forum.
Edit: You guys solved it, different order of arguments gives 1.426674
Bogdan
Posted on June 16, 2014 at 11:42
Hi guys,
thanks alot, i missed that order of y and x ....
i swaped y with x and now are ok
