2015-12-17 11:28 AM
2015-12-21 2:05 AM
Nobody can help or give me some hints?
2015-12-21 8:30 AM
That would appear to be the consensus. Forums are often like empty rooms. I don't work with F3 or HAL.
SDADC_EXT_TRIG_TIM13_CC1 // Probably not TIM13
2015-12-21 3:35 PM
Thanks Clive!
I have solved the problem after I have update the thread.The problem was what you pointed out. I copied the wrong string from HAL library.I had also change the order of some line, as suggested by HAL libraryRegards
