eirik
STM32F303VCT6 running ISR from ccmram
  • June 18, 2015
  • 4 replies
  • 869 views
Posted on June 18, 2015 at 22:06
Hi, I have been trying to run critical interrupt routines from ccmram with gcc toolchain following the instructions in
http://www.st.com/web/en/resource/technical/document/application_note/DM00083249.pdf
I think I have got the instructions correct, but fail to link the project. Linker emits the following message:
 section .ccmram loaded at [00000000080017a0,000000000800189f] overlaps section .data loaded at [00000000080017a0,0000000008001c17]
#stm32-ccmram
    Tesla DeLorean
    Guru
    June 18, 2015
    Posted on June 18, 2015 at 22:13
    Sounds like an issue with the linker script then... might want to review that.
    eirik
    eirikAuthor
    Posted on June 18, 2015 at 22:16
    eirik
    eirikAuthor
    Posted on June 18, 2015 at 22:18
    The original post was too long to process during our migration. Please click on the provided URL to read the original post. https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I6ha&d=%2Fa%2F0X0000000btY%2F.PFMvejScG9jm6Xm6hkDKJy9fcCaoOScw0YqizyXG2c&asPdf=false
    Tesla DeLorean
    Guru
    June 18, 2015
    Posted on June 18, 2015 at 22:56
    Pity there isn't a .ZIP of the files from the App Note provided by ST
    They probably changed the .data section
    /* Initialized data sections goes into RAM, load LMA copy after code */
    .data :
    . = ALIGN(4);
    _sdata = .; /* create a global symbol at data start */
    *(.data) /* .data sections */
    *(.data*) /* .data* sections */
    . = ALIGN(4);
    _edata = .; /* define a global symbol at data end */
    } >RAM AT> FLASH
