STM32F303 CubeMX injected conversion of ADC rank 2 do not work
l.kopp
I'm using the STM32F303 and CubeMX with low layer.
I try to read two ADC-values with the injected conversion. In CubeMX i defined two ranks to read the values from the ADC. For rank 1 everything works fine and in the JSQ1 register contains the right channel. For rank two i'd like to read channel 1 but in the JSQ2 register channel 0 is selected.
Have anyone a solution for this problem ?
Thanks, L.
0 REPLIES 0
