2013-09-14 01:53 AM
I use STM32F217 USB-HS Demo to STM3221G-EVA board(STM32F217IG 176pin) and it works well,
now I have a project to implement preceding function but I only have STM32F217VG(100 pin) without PH4(ULPI_NXT) and PI11(ULPI_DIR). May I change PH4 to other GPIO and how to alter codes or other method to solve it? Many thanks.2013-09-14 02:45 PM
You could observe the alternative pins PC3 and PC2 in the
http://www.keil.com/dd/docs/datashts/st/stm32f2xx/cd00263874.pdf
Modify the code that enables/configures the GPIO pins and clocks.
