2014-03-25 06:58 AM
I'm trying to locate the whereabouts of the an2629.zip file that contains code that is used to measure the current consumption of a STM32F01x as described in the AN2629 (Doc. ID 13922 Rev2). I've tried to locate it on the ST site (found a link on the WWW)http://www.st.com/stonline/products/support/micro/files/an2629.zip
via a website (http://www.rs-online.com/designspark/electronics/knowledge-item/stm32f101xx-and-stm32f103xx-low-power-modes-) This however resulted in a Page not found - 404. Anyone? Thanks in advance for your time. Regards, Gerben2014-03-25 07:04 AM
Is this what you are looking for?
http://www.st.com/web/en/catalog/tools/FM147/CL1794/SC961/SS1743/PF257848?s_searchtype=keyword#2014-03-25 07:48 AM
2014-03-25 08:40 AM
On the link given by Sung, you can find both the software to download & the document.
-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
2014-03-26 05:35 AM
Ok, I see now. At first I ignored the ''Download'' button because of the ''Order From ST'' which I associated with ''you need to pay''. My mistake. :)
Thanks for pointing out. Kind regards, Gerben
