2024-09-07 6:07 AM - last edited on 2025-03-21 5:24 AM by Amel NASRI
in the process of or at least i want to backup the mcu data and transfer it over to another mcu, i can connect and see the mcu with my pe cyclone fx but when i read and dump the data i get a empty file 768kb.
S3150800000000000000000000000000000000000000E2
S3150800001000000000000000000000000000000000D2
S3150800002000000000000000000000000000000000C2
S3150800003000000000000000000000000000000000B2
S3150800004000000000000000000000000000000000A2
S315080000500000000000000000000000000000000092
S315080000600000000000000000000000000000000082
S315080000700000000000000000000000000000000072
S315080000800000000000000000000000000000000062
S315080000900000000000000000000000000000000052
S315080000A00000000000000000000000000000000042
S315080000B00000000000000000000000000000000032
S315080000C00000000000000000000000000000000022
S315080000D00000000000000000000000000000000012
S315080000E00000000000000000000000000000000002
2024-09-07 1:48 PM
That would explain what you're seeing. It would help if you told us what the RDP option byte is set at. Shouldn't have to guess.
2024-09-07 1:54 PM
This is all new to me , I am no expert hence am here asking for help , to some one that does this on a daily bases gurus and experts it’s common things to look for , To us learning and tinkering around it’s all a learning process, I do want to thank every one that provided any type of opinion in the hopes of helping me out , than you every one .
