stm32f103c6t6 arm controller printf is not working.
Sm.1
hi im using stm32f103c6t6 arm controller printf is not working i followed steps which provided a peace of code attached. 0693W00000bhHG0QAM.png
10 REPLIES 10
Ok so Keil
You initialize the UART, pis, etc.
Does that work for outputting using the HAL_UART_Transmit() directly?​
Sm.1
yes its working fine but i need to print it using printf if i put printf its not working.
for that im enabling led in EV board if i put printf the loop is not running.
@Community member​
https://community.st.com/s/article/how-to-redirect-the-printf-function-to-a-uart-for-debug-messages
This example i referred which is from stm community. not worked
#include <rt_misc.h>
#if 0 // enable for Keil 5.xx compilers
#pragma import(__use_no_semihosting_swi)
struct __FILE { int handle; /* Add whatever you need here */ };
FILE __stdout;
FILE __stdin;
#endif
Make sure "Use MicroLIB" is checked in Target window
Use #include <stdio.h>
and above fragment
Still doesn't work, going to need to use the debugger
hey @Community member​  its not working same problem if i put printf in while loop the loop not executing.i pasted my code down please resolve my problem.
#include "main.h"
#include <stdio.h>
/* USER CODE END Includes */
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* USER CODE BEGIN PM */
/* USER CODE END PM */
ADC_HandleTypeDef hadc1;
UART_HandleTypeDef huart2;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
static void MX_USART2_UART_Init(void);
static void MX_ADC1_Init(void);
/* USER CODE BEGIN PFP */
FILE __stdout;
FILE __stdin;
#endif
//#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
//PUTCHAR_PROTOTYPE
// HAL_UART_Transmit(&huart2, (uint8_t *)&ch, 1, 0xffff);
// return ch;
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
 * @brief The application entry point.
 * @retval int
int main(void)
 /* USER CODE BEGIN 1 */
 /* USER CODE END 1 */
 HAL_Init();
 /* USER CODE BEGIN Init */
 /* USER CODE END Init */
 SystemClock_Config();
 /* USER CODE BEGIN SysInit */
 /* USER CODE END SysInit */
 MX_GPIO_Init();
 MX_USART2_UART_Init();
 MX_ADC1_Init();
 /* USER CODE BEGIN 2 */
 /* USER CODE END 2 */
 /* Infinite loop */
 /* USER CODE BEGIN WHILE */
 char a[]={"\n"};
int AD_RES=0;
float Voltage;
char AD_RES_r[1]={0};
uint8_t data[1]={0};
 /* Infinite loop */
 while (1)
  /* USER CODE END WHILE */
HAL_GPIO_TogglePin(GPIOC, GPIO_PIN_13);
HAL_Delay(100);
//HAL_UART_Transmit(&huart2,a, sizeof(a),0xffff );
   printf("hello sln\r\n");
//puts(a);
  /* USER CODE BEGIN 3 */
 /* USER CODE END 3 */
#include "main.h"
#include <stdio.h>
// Hosting of stdio functionality through USART
/* Implementation of putchar (also used by printf function to output data)    */
int __io_putchar(int ch)  /* Write character to Serial Port     */
// SWV Method using PB3 / SWO
//  ITM_SendChar(ch); // From core_cm4.c
  return(ch);
FILE __stdout;
FILE __stdin;
#endif
int fputc(int ch, FILE *f) { return (__io_putchar(ch)); }
int ferror(FILE *f)
  /* Your implementation of ferror */
  return EOF;
void _ttywrch(int ch) { __io_putchar(ch); }
void _sys_exit(int return_code)
label:  goto label;  /* endless loop */
 * @retval int
int main(void)
  char a[]={"\n"};
  int AD_RES=0;
  float Voltage;
  int i = 0;
  HAL_Init();
  MX_GPIO_Init();
  MX_ADC1_Init();
  /* Infinite loop */
  while(1)
    HAL_Delay(100);
    printf("hello sln #%d\r\n", i++);
Sm.1
the problem is same for this code too. i loaded your code see suddenly the loop is hanging and led not working i'm not getting why its not working. In other stm family that small code is working but here not working.
Perhaps try using the debugger?​
USART2 PA2 PA3 ?​
Sm.1
yea some problem with usart2 its not working. but for usart one also unable to print but its working fine in debug mode.
