STM32F1/F4 incompatible I/O
Options
‎2011-12-08 10:34 AM
Posted on December 08, 2011 at 19:34
From their respective RMs:
STM32F1... 0x4002 2000 - 0x4002 23FF Flash memory interface STM32F4... 0x4002 2000 - 0x4002 23FF GPIOI Thus a project predicated on STM32x compatibility must have at least different I/O base addresses based on processor type. Damn! I guess I have to say it again, “substantial compatibility� or in ST’s case, “compatible�, means incompatible. Now I have to go through, identify all the differences and come up with a way to select the proper include files. Does anyone know if the (possibly subset of) I/O offset address are always the same?
4 REPLIES 4
Options
‎2011-12-12 9:27 PM
Posted on December 13, 2011 at 06:27
If you compile a list, please post.
Options
‎2011-12-13 12:02 PM
Posted on December 13, 2011 at 21:02 Hi The memory mapping changes of some peripheral blocks are quite a small difference. It is to be noted that there are various larger differences in the peripheral blocks themselves. - the clock module and internal bus clock configuration is quite different - the peripheral pin configuration is quite different - the Flash modules are very different (rather than a 1k, 2k or 4k Flash granularity that the F1 has the F4 has different Flash sector sizes from 16k to 128k which makes it totally incompatibe with file system implementations). I am working on a document showing the differences (and how to make a project compatible will all types) here:
http://www.utasker.com/docs/STM32/uTaskerV1.4_STM32_Developers_Document.pdf
Regards MarkOptions
‎2011-12-13 5:08 PM
Posted on December 14, 2011 at 02:08
Thanks!
I created this article a couple weeks ago. I still need to add a big overview section, expand STM32 F1, add STM32 W, add some photos. http://en.wikipedia.org/wiki/STM32 I started overhauling this article last weekend. It still needs a lot of work. http://en.wikipedia.org/wiki/ARM_Cortex-M I need to spend some time to examine uTasker. I looked at it briefly when expanding these articles. SteveOptions
‎2011-12-14 7:41 AM
Posted on December 14, 2011 at 16:41
Here is another free RTOS
