2018-04-09 03:56 AM
Hello All,
I am using STM32F030C8 MCU. I have configured SWCLK pin as output and programmed it. but after configuring the SWCLK pin as output, I am not able to reprogram the MCU again with programmer. Please help!!!#
2018-04-09 05:01 AM
Pull BOOT0 High and reset before trying to program, or use Connect Under Reset option if you have NRST pin connected.
